TwinTurbo.NET: Nissan 300ZX forum - Removing the rear traction/toe rod
Subject Removing the rear traction/toe rod
Posted by ZX-infinity (Dallas) on April 15, 2010 at 11:42 AM
  This message has been viewed 192 times.
Message There is a metal gas line from the gas cap in the way of removing
the bolt from the subframe connection point. One end is bolted
with 6 10-mm nuts. Is it safe to remove these to get enough
clearance to remove the traction/toe rod bolt?
I was given the suggestion to cut the bolt head off and remove
it from the other side, and replace it going the other direction.
Any other suggestions?
